Thread: Batch export to an earlier version of CAD
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,124
    Default Batch export to an earlier version of CAD
    i have a project that we are trying to send files out to a sub on, and they are still using AutoCAD 2000. is there some way i can do a batch save-as / export for quite a few drawings to 2000? i tried e-transmit, but it crashed everytime i did. there are a number of xref's, but i would like to keep xref's seperate (not bound) to the various files they are referenced in. i managed to export some with xref's bound, and file sizes went from 1k to 40mb, which is ridiculous imo.
    This aggression will not stand. Man.
    Houston
    7,519
    Default Re: Batch export to an earlier version of CAD
    eTransmit is the way.... but if you can't get it work....
    Are you running a vertical or is this vanilla AutoCAD?
    You could also use DWGTrueConvert if you have the older version. If not, the DWG converter is part of DWG TrueView now.
    http://www.autodesk.com/dwgtrueview
    2006-04
    1,124
    Quote Originally Posted by rkmcswain
    ACA 2008
    i will look into true convert after lunch. thanks. any ideas why eTransmit crashed? it did it several times in a row.
    Houston
    7,519
    Question Re: Batch export to an earlier version of CAD
    Quote Originally Posted by Chad_C
    ACA 2008
    You might want to start the download now - it's a big one.
    Just some guesses, but maybe one of the drawings or reference drawings:
    • ...needs to be Recovered or have Audit run on it.
    • ...is missing a reference of it's own, like a shape file?
    • ...is locked
    • ...has some other sort of problem that would cause a dialog to appear in the editor?
    2006-04
    1,124
    this seems to do the trick. thanks
  1. Export to earlier version
    By amaser in forum Dot Net API
    Last Post: 2011-04-14, 06:55 PM
  2. Saving to earlier version, STB to CTB
    By dwescott in forum CAD Standards
    Last Post: 2010-02-19, 11:06 PM
  3. Batch Process files to a earlier version using Save AS
    By mserapiglia in forum CAD Management - General
    Last Post: 2009-01-23, 11:37 PM
  4. Batch, save as, to earlier CAD version
    By wardorichie in forum Design Review - General
    Last Post: 2008-07-23, 12:55 PM
  5. save to earlier version
    By iffans in forum Revit Architecture - General
    Last Post: 2005-04-08, 05:59 AM
