Thread: Error - Reloading Family "caused deletion of non-editable workset"
    2006-04
    Baltimore, MD
    379
    Default Error - Reloading Family "caused deletion of non-editable workset"
    To start things off - we just upgraded our project and families yesterday to 2008, so I'm not sure if that is part of the problem. I edited a toilet family, but when I try to reload I get the error message "This action has caused deletion of non-editable Workset 'Family: Level Head: Level Head - Upgrade." When I click on "Make Elements Editable," the message won't go away.
    I've tried a few things myself, which have all failed:
    1. Making the workset editable before reloading
    2. Deleting the Level Head - Upgrade (select all instances is greyed out)
    3. Changing the name of the toilet family, which worked to get the toilet in, but now I have the original family that I can't delete without the same error message
    For now I can live with it, but my fear is that this will happen with another family. Has anyone else experienced this, or have any other suggestions?
    Thanks in advance,
    Laura
    2006-04
    Baltimore, MD
    379
    Default Re: Error - Reloading Family "caused deletion of non-editable workset"
    I'm not entirely sure what happened, but I this morning I was able to delete the offending workset. I made it editable, did a purge unused and was able to delete the Level Head Family along with the toilet family. I had tried the same thing yesterday, but it didn't work then. Oh well, it's out of my file now.
    Active Member Rustle's Avatar
    2007-10
    Portland, OR
    69
    We get stuck in a "Make Editable" loop that never ends when we try to delete the "upgrade" level.
    2006-02
    23
    See this link for resolution:
    http://forums.augi.com/showthread.ph...860#post935860
    Regards,
    Shruti Harve
    Ideate,Inc
    http://www.ideateinc.com/educate/index.html
    Shruti Harve-Ideate
  1. error help - "The parameter Description doesn't exist in the Family.."
    By ddenton in forum Revit Architecture - Families
    Last Post: 2013-02-22, 06:30 PM
  2. "This action has caused the deletion of non-editable workset..."
    By twiceroadsfool in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-02-01, 09:14 PM
  3. "this action has caused the _____ workset to be deleted"
    By DanInMiami in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-11-10, 11:39 PM
  4. "such-n-such family is currently not editable..."
    Last Post: 2010-07-16, 03:19 PM
