Hi, I have a Project I started off with the building model without any site information. The site information (Site.dwg) unfortunately was provided after the building model was completed. I linked the Site.dwg into my project at True North and then reset to Project North. Later I found out that the building model was a bit off about 10 degrees to the East at True North setting. Now, I have to reset/rotate the building 10 degrees West as it should be without affecting its alignment at Project North setting. The problem I am having is I am rotating the True North but every time I relink, the site.dwg always inserts at the same old location and angle as if I have not rotated anything at all.
When I Rotate the building 10 degrees West at True North and reset back to Project North, the building alignment is off by that.
Is there a proper way to do this?
Thanks in advance
