Results 1 to 7 of 7
Thread: Dynamic Block acts weird when copied to and pasted from clipboard
    2003-05
    335
    Default Dynamic Block acts weird when copied to and pasted from clipboard
    Check this out! Has anyone ever seen their DBs do this? When this portion of a dwg was copied to the clipboard and pasted back into the original dwg some of the blocks get all weird.
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Default Re: Dynamic Block acts weird when copied to and pasted from clipboard
    Uhuh, even does it when you copy it into another drawing twice. Well Will, i'd say you got yaself puzzle there
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    I'm not going to climb onto my soap box again so soon, but this is another reason to use the COPY command instead of accelerator keys. It is possible the block table was corrupted somehow when the DB was copied into the drawing. Try an AUDIT and PURGE to see if it fixes anything.
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by whdjr
    I have no solutions for this OTHER than saying that the drawing displays two different behaviours ....
    when the accelerator keys are used (for me it's Ctrl+C), the block goes all wonky.
    when the COPY command is entered, the block comes out fine.
    maybe don't use the accelerator keys when using this block ....
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    i've sent out e-mails to my group saying to to copy-paste most DBs for this very reason. tho, mostly my googly issues are field related...
    S&D DB Sharing Forum
    100 Club wroebuck's Avatar
    2004-07
    Chico, CA
    158
    I have noticed this with just geometry too. I have retrained myself to stop using the Ctrl+C copy for that reason. I've seen dynamic blocks lose grips even thought when opened in block editor they are fine. Something definitely is up.
    2004-07
    Austin, Texas
    148
    Accelerator keys and the AutoCAD copy command are two entirely different animals. CTRL-C copies out to the clipboard, Copy does not.
  1. 2016: dynamic block door - 90degrees stretch action acts reversed when flipped
    By architurk in forum Dynamic Blocks - Technical
    Last Post: 2015-08-24, 08:00 PM
  2. Replies: 0
    Last Post: 2012-12-05, 11:16 PM
  3. Weird dynamic block behavior
    By Raudel Hinojosa Sr in forum Dynamic Blocks - Technical
    Last Post: 2008-07-08, 02:04 PM
  4. Replies: 7
    Last Post: 2006-05-11, 01:36 AM
  5. 3d Orbit acts weird
    By kgray.65984 in forum AutoCAD General
    Last Post: 2004-09-03, 05:20 PM
