TeriblTim
OK, so I've done some searching on this topic and I think I get it. But help me out here. You can only put one "base point parameter" in a DB and that will be the insertion point of the DB, with no "base point parameter" the insertion point is 0,0. But can you put multiple "points" (draw/point/single point) in the DB and use them as insertion points? And if so, how do you toggle between them on insertion? I know you cn pick an insertion point using the dynamic input pulldown list or whatever, but will the insertion point remain as an active grip after insertion? I would like to have multiple grips that I could just move the whole block with instead of just the one grip at the insertion point. Did any of that make sense?
