Thread: Lighting Fixture Schedules - HELP!
    Active Member Mottiqua's Avatar
    2006-09
    96
    Default Lighting Fixture Schedules - HELP!
    I'm using the "lighting devices" category for my wall mounted light fixtures...
    Problem is that I can't get them to appear in a schedule like my other light fixtures.
    I'm trying a multi-category schedule, but I can't get it to work....
    Any thoughts?
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    889
    Default Re: Lighting Fixture Schedules - HELP!
    Quote Originally Posted by Mottiqua
    Any thoughts?
    how are you filtering the schedule?
    2006-09
    96
    Through "type comments"
    I'm adding in "Fixtures" so that it doesn't pick up my regular lighting devices....(I also put it in my parameters of my regular ltg fixtures)
    But it's not picking up anything at this point
    I could stop if I wanted to dmb.100468's Avatar
    2005-11
    Virginia
    222
    If you are using shared parameters that are applied to your fixtures and the devices you wish to schedule then the multi-category should work. (gonna test it)
    I know this isn't much help, but I made my wall mtd lights as "fixtures" and created a subcategory for the symbolic lines in the family, so the architect can turn them off in the reflected clng plan.
  1. Lighting fixture - Row issue
    By SamuelAB in forum Revit Architecture - General
    Last Post: 2011-09-07, 02:23 PM
  2. Lighting Fixture
    By daryl.marshall in forum Revit MEP - Families
    Last Post: 2011-05-16, 07:20 AM
  3. Lighting Fixture Tag
    By Beancud in forum Revit MEP - Families
    Last Post: 2009-02-12, 01:20 PM
  4. Lighting Fixture
    By MNsnowtaTy in forum Revit MEP - General
    Last Post: 2008-04-17, 08:50 PM
  5. lighting fixture schedule is not the same
    By schizoidDrafter.9 in forum AMEP General
    Last Post: 2008-01-13, 01:23 PM
