Results 1 to 8 of 8
Thread: Count No. of Blocks
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Default Count No. of Blocks
    Hi all,
    Is there a field that can be inserted in to a cell to count the number of named blocks?
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Default Re: Count No. of Blocks
    Best of luck to you on this one. I've been trying to figure out the same thing for weeks. My only suggestion is to use the block counting command, then enter the values manually.
    I loved the NCS so much, I joined the committee!
    "Truth suffers from too much analysis"
    I remember AutoCAD R10
    When will Autodesk port AutoCAD to Linux?
    2002-11
    270
    That's how I've been doing it but I was hoping that with ACAD 2008 that would have been added, but I agree with you on that..
    2001-03
    13,499
    Hi
    Not a Field, but the following offers a workable solution (granted it take a little bit of setting up, but once done...).
    Count the number of Blocks in a drawing file
    Correctly calculating totals in a Table
    [thread=23876]Undocumented AutoCAD 2006 Commands - EAttExtEdit and EAttExtUpdate[/thread
    Have a good one, Mike
    2002-11
    270
    Thanks for the links, Mike, but it's all over my head - I think I'll stick to counting the blocks via qselect & entering the info manually.
    Houston
    7,519
    Exclamation Re: Count No. of Blocks
    Quote Originally Posted by kwong
    Hi all,
    Not a field, but you can easily create a TABLE that includes the quantity of all (or certain) named blocks in the drawing. This table is dynamic and will update when the quantities change.
    Command: ._EATTEXT
    -or-
    Command: ._DATAEXTRACTION
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    Quote Originally Posted by rkmcswain
    Command: EATTEXT
    EATTEXT a.k.a attribute extractor
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    pre-2008 version of the data extraction needs to be done thru the wizard. there's a check box in there to calculate totals. i don't know how to add this after the fact before 2008 tables...
    like rk says, once table is created, all you need to do is refresh when modifying the source drawing.
    S&D DB Sharing Forum
  1. Count blocks in a VB script
    By kmelchor in forum VBA/COM Interop
    Last Post: 2010-02-08, 08:27 PM
  2. Ability to count blocks
    By schrodingerscat in forum DWG TrueView - Wish List
    Last Post: 2008-10-14, 05:36 AM
  3. Count Blocks inside Property Set Definition
    Last Post: 2007-09-12, 02:03 PM
  4. Replies: 1
    Last Post: 2007-01-05, 12:38 AM
  5. Count Blocks Tool
    By bDOUGH15 in forum Land Desktop - General
    Last Post: 2004-09-16, 02:15 AM
