Thread: Electrical Wire Trying to Connect to HVAC Connectors
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    889
    Default Electrical Wire Trying to Connect to HVAC Connectors
    I have an exhaust fan in which I am trying to connect electrically. It has two connectors, one for HVAC and one for electrical. When I lead a wire from the electrical connector, it will automatically connect itself to the HVAC connector and not associate itself with the circuit or give me a home run arrow. Anyone know why it is doing this or has seen it before?
    Thanks
    Active Member Mottiqua's Avatar
    2006-09
    96
    Default Re: Electrical Wire Trying to Connect to HVAC Connectors
    You don't have any parameters in the electrical connection that might have it looking back to the hvac connection (like if the hvac connection itself has a parameter for voltage in lieu of the family)? I don't see how this is possible because they're 2 completely different connections.
    I have my mechanical families set up with shared parameters for voltage, phase, amps, VA, etc.....and have them mapped to my electrical connector....haven't had a problem yet.
    *fingers crossed*
    2007-03
    889
    Quote Originally Posted by Mottiqua
    *fingers crossed*
    yeah, thats exactly how I do it. I am kind of puzzled why it is giving me this.
    I could stop if I wanted to jlondenberg's Avatar
    2007-03
    460
    We have also had this issue on a couple of AC units we built. For at least one family the work around was to reduce the number of connectors on it. A furnace with 2 duct connectors, 3 plumbing connectors and 1 elec connector didn't work. By removing the plumbing connectors we got it to work again (we have not started doing pluming drawings in Revit yet)
    We submitted this to Autodesk support and have yet to hear of any progress.
  1. Multiple Electrical Connectors
    By repp in forum Revit MEP - Families
    Last Post: 2012-11-09, 02:20 PM
  2. 2011: Duct Connectors - drag to connect to other connectors
    By bb1 in forum Revit MEP - General
    Last Post: 2011-09-07, 07:56 PM
  3. 2011 Multiple Electrical Connectors
    By mattm572209 in forum Revit MEP - General
    Last Post: 2011-09-02, 04:41 PM
  4. Wire does not clean up to Electrical Device
    By jgilroy in forum AMEP General
    Last Post: 2010-09-02, 03:18 PM
  5. Electrical Connectors
    By trent.chambers in forum Parts Builder
    Last Post: 2010-06-09, 07:10 PM
