Results 1 to 6 of 6
Thread: Object in Paperspace vs Modelspace
    100 Club matt.worland's Avatar
    2015-12
    Denver, CO USA
    174
    Question Object in Paperspace vs Modelspace
    Our VBA guy was wondering what are some ways to determine whether an object is in paperspace or modelspace. Any takers?
    Thanks
    Matt
    I could stop if I wanted to msretenovic's Avatar
    2002-02
    Galloway, Oh
    305
    Default Re: Object in Paperspace vs Modelspace
    Matt,
    You could get the OwnerID of the object. Once you have that, iterate through the Blocks collection and try to match the OwnerID you found to an ObjectID. If it is in a block, you may need to call it recursively to get to either Model Space or Paper Space. You can check the Name property to see if it is a block or model/paper space . If it is model space the Name property will return *MODEL_SPACE. If it is in paper space, the Name property will return *PAPER_SPACE .
    HTH
    2015-12
    Denver, CO USA
    174
    I told him that is how I did it in v-lisp, but he was hoping for an easier way.
    Thanks for the re-enforcement, I will let him know.
    Matt
    2000-01
    Seattle WA USA
    5,859
    Lightbulb Re: Object in Paperspace vs Modelspace
    Quote Originally Posted by msretenovic
    You could get the OwnerID of the object. Once you have that, iterate through ...
    Um, no need to iterate.
    Sub Test()
    ' Test assumes at least one entity in both ModelSpace & Layout1
      With ThisDrawing.ModelSpace
        Debug.Print GetOwningLayout(.Item(.Count - 1)).Name
      End With
      With ThisDrawing.Layouts.Item("Layout1").Block
      End With
    End Sub
    Private Function GetOwningLayout(Entity As AcadEntity) As AcadLayout
      Set GetOwningLayout = ThisDrawing.ObjectIdToObject(Entity.OwnerID).Layout
    End Function
    2002-02
    Galloway, Oh
    305
    Talking Re: Object in Paperspace vs Modelspace
    Huh, didn't know about that function. Now I do . Thanks Robert!!!
    2002-02
    Kansas
    487
    Get the object that the ownerId points to; Use ThisDrawing.ObjectIdToObject
    Check the OwnerId of this Object IF = 0 then you have the Top Object ;else get the Owner of this Object
    when you get the Top Object if it a block and IsLayout = Ture then the Object is in Paper Space else It In Model_Space
    use "If TypeOf obj Is AcadBlock Then" to test for block and "If obj.IsLayout then" to test for IsLayout" do not put bouth in the same If Statement if the obj is not a block the IsLayout will error out
    IF the Top object is not a block then the object you stated with is not a entity
    Change Sorry isLayout will not work need to Check name of obj for *Model_Space
    Public Function MSorPs(vObj As AcadObject)
    'this function reture MS if object is in MS
    ' PS if object is in PS
    ' NA if not a Entity
    Dim fnObj As AcadObject
    Dim fnOwnerObj As AcadObject
    Set fnObj = vObj
    Set fnOwnerObj = ThisDrawing.ObjectIdToObject(fnObj.OwnerID)
    'get the Top object
    While fnOwnerObj.OwnerID <> 0
    Set fnObj = fnOwnerObj
    Wend
    'Check if block
    If TypeOf fnObj Is AcadBlock Then
    'Check if Model Space
    If fnObj.Name = "*Model_Space" Then
    	MSorPs = "MS"
    	Else
    	MSorPs = "PS"
    	End If
    Else
    MSorPs = "NA"
    End If
    End Function
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Replies: 9
    Last Post: 2007-01-10, 09:28 AM
  3. Replies: 2
    Last Post: 2006-12-27, 10:16 PM
  4. Move Object from Paperspace to Modelspace
    By DONCORINO in forum AutoCAD General
    Last Post: 2006-02-15, 06:01 PM
  5. Link a object in Modelspace to a Field in Paperspace
    By Spectrefish in forum AutoCAD Fields
    Last Post: 2005-02-04, 10:21 PM
