gordon.hayner
In our company all text must be left justified, (it is frustrating but it would take an act of congress to change). We are learning AutoCAD 2007 and I want to have the leader text be left justified but I am running into a few problems. First, when I select, "Always Left Justify", the box that I would check to, "Prompt for Width" is grayed out as shown below. Is there a way I can set the width and still have it left justified? The work around is to hit return after each line but that limits mtext. Also if I do set the leader to always use left justified text, (and get multiple lines by hitting the return key), but find I have to move a leader from left to right the text becomes right justified. I have noticed this problem in previous versions of AutoCAD but I hoped if would be fixed.
Just to clarify, this is about the Leader Settings Dialog that works with the command QLEADER not LEADER.
