Thread: opening a new drawing
    Member zfoland20's Avatar
    2003-05
    Indianapolis, IN
    40
    Default opening a new drawing
    Is there a system variable that sets whether the initial drawing when you start AutoCAD closes once you open a different drawing?
    2001-10
    Arizona
    2,337
    Default Re: opening a new drawing
    SETVAR
    SDI
    Type: Integer
    Saved in: Registry
    Initial value: 0
    Controls whether AutoCADruns in single- or multiple-document interface. Helps third-party developers update applications to work smoothly with the AutoCAD multiple-drawing mode.
    0 Turns on multiple-drawing interface.
    1 Turns off multiple-drawing interface.
    2 (Read-only) Multiple-drawing interface is disabled because AutoCADhas loaded an application that does not support multiple drawings. SDI setting 2 is not saved.
    3 (Read-only) Multiple-drawing interface is disabled because the user has set SDI to 1 and AutoCAD has loaded an application that does not support multiple drawings. (SDI was set to 1 before the application was loaded.) SDI setting 3 is not saved.
    If SDI is set to 3, AutoCAD switches it back to 1 when the application that doesn't support multiple drawings is unloaded.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    150700
    3,421
    Quote Originally Posted by mjfarrell
    SETVAR
    SDI
    Type: Integer
    Saved in: Registry
    Initial value: 0
    Note that if you set this to 1, which will solve your problem, you will not be able to have multiple drawings open in one session of AutoCAD
  1. I want to create a drawing without opening a drawing.
    By mikeosborne in forum VBA/COM Interop
    Last Post: 2009-10-01, 06:12 PM
  2. New Drawing Opening Without DWT Dialog Box
    By omorah in forum AutoCAD CUI Menus
    Last Post: 2008-07-17, 02:22 PM
  3. Replies: 2
    Last Post: 2008-07-09, 12:17 AM
  4. Opening a drawing has changed
    By engineering.28250 in forum AutoCAD Map 3D - General
    Last Post: 2006-09-19, 05:29 PM
