Results 1 to 6 of 6
Thread: workset - visible by default in all views
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Default workset - visible by default in all views
    I have a user that in his wisdow decided that all the new worksets that he created should not be visible by default in all views. so now he is going around to each view and having to make them visible (not too bad with view templates, or i told him to make a new work set and move everything on the "bad" workset to the new).
    I was wondering if there was anyway to reverse this?
    Justin
    2004-06
    Memphis TN area
    7,048
    Default Re: workset - visible by default in all views
    Only thing I know to do is to create new worksets to replace each existing one, and delete each existing one, moving everything to the new one that replaces it.
    2006-04
    Calgary, Alberta
    143
    Justin, could you use view templates?
    2004-07
    954
    yeah that is what i mentioned in the original post. I was just wondering if there was a "switch" that could do this goblaly seeing as this was a button that made a gobal change from the start.
    (edit the best method we came up with is to create a new workset, then in the dialague box delete to offensive workset. Revit then asks what would you like to do with the items in that workset, so you then place them on the new work set).
    Justin
    Last edited by Justin Marchiel; 2007-06-21 at 11:48 PM. Reason: found a better way
    2006-04
    Calgary, Alberta
    143
    Oops, I see now that I suggested what you already mentioned. My bad.
    Good solution with the new workset!
    Regards,
    Bruce
    2005-07
    3,250
    View templates aren't a solution...you cannot control workset visibility through them.
  1. workset not visible by default
    By david_peterson in forum Revit Architecture - General
    Last Post: 2012-09-05, 04:54 PM
  2. How to make Specify Workset dialog box opened by default?
    By zaytsev77 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-11-16, 06:59 PM
  3. Making a workset not be visible by default AFTER creation
    By dbaldacchino in forum Revit Architecture - Tips & Tricks
    Last Post: 2010-11-11, 03:53 PM
  4. Make a workset off by default?
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2007-01-31, 03:30 PM
  5. Workset visible but frozen?
    By paullee in forum Revit Structure - General
    Last Post: 2006-08-09, 09:03 PM
