Thread: line based family component placement ignore snaps?
    2007-04
    50
    Default line based family component placement ignore snaps?
    Hello every body,
    when trying to place line based family component Revit ignores snap settings, even snap override... using the latest build (20070607_1700). Is this intended / confirmed behaviour?
    Regards Frantisek Stafek.
    2007-04
    50
    Default Re: line based family component placement ignore snaps?
    After little bit more trying it seem to me it goes this way:
    - if the line based (2pick) component is placed with setting "place on face" - (for example floor), it behaves as described - during the time of placement even if e.g. snapping to end of some line, component is placed just on the place where the mouse arrow just is, ignoring the snap settings or even override.
    - if it is placed with setting "place on work plane", than everything goes ok, snapping works.
    Don't know if it is just what it should be or not, but I'm glad that at least this second option works for me:-]
  1. Line Based CLOUD Detail Component!
    By bowlingbrad in forum Revit Architecture - Families
    Last Post: 2022-11-04, 01:32 PM
  2. Modify Nested component parameters in Line Based Family
    Last Post: 2012-06-21, 01:43 PM
  3. line based component ends
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2012-01-25, 06:27 PM
  4. Wall Based Family - Placement Side Confusion
    By brent.130528 in forum Revit Architecture - General
    Last Post: 2010-09-22, 02:39 PM
  5. Line based family - nested component not updating properly
    By dfriesen in forum Revit Architecture - Families
    Last Post: 2007-10-26, 04:42 PM
