Thread: Default settings
    Member costas.vassiliou's Avatar
    2004-07
    Nicosia - CYPRUS
    34
    Thumbs up Default settings
    During dimensioning, ACAD displays dimension value with 4 or 5 decimal places.
    I always choose precision 0, i.e I do not want decimals.
    Is there a way to set this as default ?
    2001-03
    13,499
    Default Re: Default settings
    Hi
    Please note I've *moved* this Topic (Thread) from the AutoCAD Customization Forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    2001-03
    13,499
    Hi
    Within your Dimension Style take a look at the following -
    PullDownMenu: Dimensions -> Style -> Dimension Style Manager dialog -> Modify button -> Primary Units tab -> Under Linear Dimensions "Precision" drop-down box + Zero Suppression "Trailing" & Under Angular Dimensions "Precision" drop-down box + Zero Suppression "Trailing"
    You could set-up your required DimStyle(s) with a Template file (.DWT) then use that file as the bases of all your New drawings
    You could then use something like DesignCenter to import your DimStyle(s) from your Template file into a current drawing file
    Have a good one, Mike
  1. change default settings
    By houston.cad in forum Revit Architecture - General
    Last Post: 2011-02-28, 08:08 PM
  2. default settings
    By cookie in forum Revit MEP - General
    Last Post: 2009-05-28, 12:51 PM
  3. Default arrowhead settings
    By Gordon.Price in forum Revit Architecture - Families
    Last Post: 2007-05-02, 11:50 PM
  4. Section Default Settings
    By ejc in forum Revit Architecture - General
    Last Post: 2007-04-12, 02:26 PM
  5. Default Settings
    By jenniferchavez in forum Land Desktop - General
    Last Post: 2004-11-13, 02:14 PM
