Thread: More Detailed Error mesages
    Wish List Administration
    2006-03
    1,102
    Default More Detailed Error mesages
    Summary: More detailed error messages that will aid in the diagnosis, making it simpler to fix the errors
    Description: I would like the error messages of sketches, assembly constraints and such to give more information as to why it failed or what pieces of geometry caused the failure.
    How Used: The current method of failure feedback in all segments of Inventor is "ok", but I believe that it could be greatly improved by including in the description the geometry that is causing the failure and also a better more detailed explanation of why it failed.
    Feature Affinity: Other
    Submitted By: Kendred Cooper on June 8, 2007
    2011-08
    4,581
    Exclamation Re: More Detailed Error mesages
    Product and Feature: Inventor -
    Submitted By: kendredcooper on 06/08/2007
    2006-04
    11
    Default Re: More Detailed Error mesages
    Wish no 9, 15 and 28 could easily be gathered in one wish.
  1. Detailed Error Messages on XREF Binding
    Last Post: 2008-10-12, 06:26 PM
  2. detailed cut out view
    By tonypazjr1 in forum AutoCAD General
    Last Post: 2008-04-22, 03:50 PM
  3. Detailed Room Plans
    By hirschnc in forum Revit Architecture - General
    Last Post: 2007-01-20, 09:42 AM
  4. DETAILED VIEWS
    By kjolly in forum Inventor - General
    Last Post: 2005-09-01, 04:43 PM
