Thread: Recover a Drawing File
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Recover a Drawing File
    I have a .dwg file that i can not open.
    I opend Autocad and did a recover and
    still can not access the Drawing File.
    The system does not have a .sv$ saved file
    How can I recover the bad .dwg file.????
    2005-07
    2,354
    Default Re: Recover a Drawing File
    Quote Originally Posted by rhayes.99001
    Is there a .bak file?
    If not what version are you using, the 2008 recover is much better than previous releases. If you don't have 2008 you can post the file and I'll try to recover and post back for you.
    2005-11
    New Jersey
    349
    Yes I have a .bak file. It would not recover as well.
    I had someone recover the file in 2008 and that worked...
    Thanks...
    2005-07
    2,354
    Thanks...
    Excellent happy I could help I'm glad you got a solution.
    I've had a few files that wouldn't recover unless I used 2008 to do so, I guess Autodesk must have improved this tool.
  1. Recover a drawing file when the Recover command fails
    By a_meteni in forum AutoCAD General
    Last Post: 2012-05-10, 05:26 AM
  2. Unable to recover this drawing
    By WhataMaroon in forum AutoCAD General
    Last Post: 2010-10-26, 07:44 AM
  3. Can't audit/recover drawing. Bad alignments?? Can't delete.
    By CJohnson.140739 in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2007-06-06, 07:17 PM
  4. Unable to recover a DWG file
    By martyk in forum AutoCAD General
    Last Post: 2006-12-05, 05:55 PM
  5. Cannot Recover drawing - AutoCAD 2005 file
    By CADKitty in forum AutoCAD General
    Last Post: 2006-10-03, 01:57 PM
