Hello,
I'm trying to learn Revit on our current residential project and I somehow don't understand underlay behavior. We've got walls with several layers (concrete, insulation, plaster, sometimes additional non bearing wall after insulation).
How do you align faces of different layers of concrete on different floors? In basement I'd like to align outer face of 350mm concrete wall without plaster or anything with specific face of 200mm concrete bearing core of compound wall of typical floor. But underlay just shows me outline of the compound wall, so the only way is to use reference planes, but this way one finds the drawing filled with reference planes, and anyway lot of cases / alignments are overseen this way.
Is there some setting or some for me hidden way for underlay behaviour?
Or what kind of workflow do you use for inner wall layers alignments across floors?
Autocad export / reimport? This just doesn't work well with lot of changes in project...
Thanks for any tip,
Frantisek Stafek
