Results 1 to 7 of 7
Thread: etransmit & shx
    2015-11
    Sydney Australia
    91
    Default etransmit & shx
    etransmit used to automatically include shx files i used for custom linetypes ... I can not find any setting to get 2008 to do this ... it is quite annoying to have to list the shx files then manually add them to the files list.
    If anyone knows how to fix this it would be greatly appreciated
    GregB
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Re: etransmit & shx
    You have to modify the transmittal setup. Check the box next to include fonts.
    Earth
    9,805
    Exclamation Re: etransmit & shx
    R.K. McSwain | CAD Panacea |
    2015-11
    Sydney Australia
    91
    Thanks ... i should have looked at the etransmit report ...
    the following is an extract of the relevant part from it
    The following files could not be located:
    linetypes
    WALL-100.(shx,ttf)
    WALL-200.(shx,ttf)
    WALL-330.(shx,ttf)
    wall-215.(shx,ttf)
    log.(shx,ttf)
    stone.(shx,ttf)
    veg.(shx,ttf)
    wall-150.(shx,ttf)
    wall-190.(shx,ttf)
    wall-230.(shx,ttf)
    wall-280.(shx,ttf)
    conc.(shx,ttf)
    brick.(shx,ttf)
    timber.(shx,ttf)
    WALL-115-PARTY.(shx,ttf)
    wall-230-party.(shx,ttf)
    fonts
    helvl.(shx,ttf)
    txt.(shx,ttf)
    myleroy.(shx,ttf)
    all are shx files that are NOT in the standard Autocad directories
    I now know that it will include them but is unable to find them.
    I have the path to these files in the support files search path, so i now need to figure out why it can't find them
    Greg B
    2002-04
    Colorado
    2,020
    If they are SHX files in the Support Path it should find them. It always has for me. I don't know why it wouldn't work for you.
    2015-11
    Sydney Australia
    91
    thanks ... i shall find out why!!!!!!!!!
    Is it just me or does there seem to be more bugs in this version (200 than 2006???
    2015-11
    Sydney Australia
    91
    Angry Re: etransmit & shx
    well I have to admit defeat on this one ... was having problems with crashing so did a repair ... thought that would fix it but alas it didnt ... oh well
  1. etransmit
    By param.cambow in forum AutoCAD General
    Last Post: 2010-08-31, 06:41 AM
  2. ETransmit
    By Tommybluegrass in forum AutoCAD Tips & Tricks
    Last Post: 2007-12-17, 02:01 PM
  3. etransmit
    By dzatto in forum ACA General
    Last Post: 2007-10-18, 05:19 PM
  4. ETransmit - What do you do...
    By kschultz in forum AutoCAD General
    Last Post: 2006-01-25, 02:37 PM
  5. etransmit
    By cds in forum ACA General
    Last Post: 2004-10-08, 11:22 AM
