hi,
i understand that a tolerance distance can be set for elements.
can it be done in Revit Architecture. or is it available in Revit MEP aor Revit Structure?
let me elaborate with an example.
if we have a air pipe running just 2" below a beam, does it show up in a inteference check?
is there a way we set the minimum clearance value? so that we can keep all the minimum clearances intact?
can we achieve this in Revit architecture for architectural components?
can we also have this retained for links between Revit Architecture, Revit MEP and Revit Structure?
