Results 1 to 8 of 8
Thread: Multileader problem
    2007-06
    32
    Default Multileader problem
    we all know that ctrl+2 brings up the design center where you can select a drawing go into say dim styles and then drag and drop dim styles from that drawing into your current drawing.
    Well it would appear autodesk have forgotten to include multileader styles in design center
    to get a MLstyle into my current drawing i have to open a blank template that has all my dim/text/multileader styles pre loaded, create a multileader, then copy it to clipboard and then paste it into the drawing i need it in
    can we get a fix or a workaround for this please?
    2005-07
    2,356
    Default Re: Multileader problem
    Why not just define a multileader tool with your reqired settings on a tool palette.
    100 Club jbayne's Avatar
    2015-12
    Standing in the corner just listening
    165
    I have created a multileader style and have put it onto a tool palette. It works great.
    Now the problem is when I have a drawing and I use the one from the palette is comes in fine and good I rclick to get shortcut menu and go to Multileader manager and tell it to use current as the standard, it does not work.
    I have to go to the tool palette every time to add a leader. It would much simpler just to type in 'ml' after setting the one I want current
    Jim Bayne
    Fat, drunk and stupid is no way to go through life, son
    Dean Vernon Wormer (Animal House)
    Member john.curschmann's Avatar
    2005-08
    31
    Question Re: Multileader problem
    I have a file I'm xrefing in multiple drawings, it has multileaders with dotblank for arrowhead, in every drawing reffing the dwg, with the layer those multileaders are on turned off, the dotblank block in the multileader is still plotting everywhere, any suggestions? I really don't want to be exploding all these.
    2015-12
    165
    It appears as though the arrowhead block was created on a different layer than the leader itself. You may have to go to the source explode one of them to find the properties then hopefully you can freeze that layer also or block edit to change all of them to the proper layer.
    Hope this helps.
    Jim Bayne
    2005-08
    31
    Smile Re: Multileader problem
    That worked, copied a multileader, exploded, edit in place dotblank to a non-0 layer, save edit, thanks!
    Autodesk should change that so dotblank layer defaults to multileader insertion layer.
    2002-04
    154
    Quote Originally Posted by guyver1 View Post
    Is there an answer to this original post?
    Jason
    100 Club darthyoga's Avatar
    2005-02
    121
    Create an mleader, drag that and the mleaderstyle command onto a toolpallette. Drag an mleader into the drawing, then reset the mleaderstyle to be current. It only has to be done once in a drawing, but may not be ideal.
    I used the CUI command to drag the mleaderstyle command over to the toolpallet and it works well.
    Grrrr.
  1. multileader
    By john.buckerfield in forum AutoCAD General
    Last Post: 2012-02-16, 03:13 PM
  2. 2012: Multileader With User Block Problem
    By mikehaff in forum AutoCAD Customization
    Last Post: 2011-11-15, 09:34 PM
  3. Multileader lisp help (mtext problem)
    By framedNlv in forum AutoLISP
    Last Post: 2010-08-09, 11:13 PM
  4. Multileader problem
    By Bilo in forum AutoCAD General
    Last Post: 2008-04-28, 01:51 PM
  5. Multileader problem
    By macha in forum AutoCAD Annotation
    Last Post: 2008-01-28, 01:25 PM
