Results 1 to 8 of 8
Thread: Xref "circular reference
    2007-02
    10
    Default Xref "circular reference
    I have xreferenced several drawings into one drawing. The main drawing name is LVL001.dwg and all the xreferenced drawings are also called LVL001.dwg except that they are in different paths. AutoCAD nicely tells me that the drawing is a circular reference even though it's in a different path. Is there some way I can change this behavior or is this an AutoCAD oops!. I know I can change the name of the referenced drawings, but this goes against my drawing numbering system.
    Alan
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Default Re: Xref "circular reference
    You have to rename one of those xref files. CAD does not allow duplicate names regardless of path. If you decide to Bind the xrefs they become blocks and you can't have blocks with same name. I don't think there is a way around it.
    I hope this helps
    2007-02
    10
    I am aware that the xref's can be bind to form blocks. My problem is that AutoCAD sees a drawing with the same name in a different path as a circular reference when it is not. See below:-
    Main Drawing
    X:\Engineering\Projects\AX\SIT\BLD\LVL001.dwg
    Xreferences
    X:\Engineering\Projects\AX\SIT\BLD\CE17\LVL001.dwg (Block Name CE17LVL001)
    X:\Engineering\Projects\AX\SIT\BLD\CE18\LVL001.dwg (Block Name CE18LVL001)
    ans so on ...
    Alan
    2006-03
    Here, Still
    549
    Quote Originally Posted by alan.rackham
    Main Drawing
    Xreferences
    ans so on ...
    Alan
    It is possible that your xref'ed files contain identical blocks names. You may have to check your blocks in your xref'ed drawings and make sure there are no two blocks with identical Names. Good Luck.
    2007-02
    10
    There are no other blocks in the drawings. I think the problem is related to the fact that AutoCAD appears to only look at the drawing name when xreferencing and totally ignoring the path of the drawing.
    2005-06
    in the upper right corner
    3,508
    Main Drawing
    Xreferences
    ans so on ...
    Alan
    As "Frimsco" mentioned, it doesn't matter what the path is, AutoCAD doesn't allow you to insert a block or xref into a file with the same name. You need to ether rename your master file or your xref(s).
    What do you mean by these block names?
    0,0,0 The Origin
    8,570
    I think Firmso's first point was that IF you were to decide to bind the xrefs THEN they would become different blocks with the same name. Since this mustn't happen, acad prevents the situation from arising by ignoring the paths.
    2007-02
    10
    Thanks for your comments, but I am aware of all that as been said so for. My point is simply that if I xreference a drawing called x:\somepath\a.dwg into x:\anotherpath\a.dwg autocad see's a circular reference when there isn't one. I have referred this to my AutoCAD dealer who appears to understand my problem so I will cross my fingers
    Alan
  1. identify the circular reference in an Xref
    Last Post: 2011-11-18, 08:33 PM
  2. Determine where a Xref Circular Reference is coming from
    By stevej.57608 in forum AutoCAD General
    Last Post: 2008-12-14, 05:43 AM
  3. dormer circular reference????
    By rstiles in forum Revit Architecture - General
    Last Post: 2008-02-20, 05:21 PM
  4. circular reference error
    By Tea_Berries in forum Revit Architecture - General
    Last Post: 2007-09-14, 07:00 PM
  5. Circular reference
    By bbaumann01 in forum ACA General
    Last Post: 2007-05-04, 12:24 PM
