Thread: Importing to object data?
    2004-07
    5
    Cool Importing to object data?
    I have extracted object data into an external data-base without any problem, but now I would like to import data to the object data table. I have an access data base that is linked to objects in my drawing. Is it possible to place this data into the object data tables? If so how do I do this.
    Larry
    2001-10
    Arizona
    2,337
    Default Re: Importing to object data?
    The following links are the keys to performing this
    'cheat' to accomplish what you want.
    First make sure you database is attached and the link template is present,
    Export the file into something like an ESRI file type.
    Then in a new map session import that file and convert to object data.
    http://usa.autodesk.com/adsk/servlet...linkID=2786831
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2009-01
    18
    Quote Originally Posted by LLCOOLJMARION View Post
    Larry
    LLcool, How did you export object data into a data base?
  1. need help....Importing Map entities and object data into google earth?
    By jmeyer.186809 in forum AutoCAD Map 3D - General
    Last Post: 2010-03-13, 11:13 AM
  2. Replies: 0
    Last Post: 2009-04-15, 02:42 PM
  3. Object data from entity to FDO Feature data property
    By vlee in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2009-04-09, 04:59 PM
  4. Importing shp files with object data
    By AAllison.Bell in forum Geospatial - General
    Last Post: 2009-03-20, 12:46 PM
  5. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
