Thread: Background color switching
    2004-07
    Detroit Michigan
    2,508
    Default Background color switching
    I have recently found a need to use a background color changing routine again.
    A simple cut/copy/paste does not require changing the background from
    black to white. However, a jpgout requires the change.
    I thought I would share my favorite routine:
     (defun C:BCOLOR ()
      (cond
    	((= (getvar "TileMode") 0)  ;Check Space, Exit if not in ModelSpace
    	 (prompt
    	   "\n***Command only works in ModelSpace, TileMode = 1***"
    	((= (getenv "Background") "16777215")
    	 ;ModelSpace Background colour = White
    	 (setenv "Background" "0")  ;Set ModelSpace Background colour = Black
    	 (setenv "XhairPickboxEtc" "16777215")
    	 ;Set ModelSpace Crosshair colour = White
    	 (setvar "TileMode" 0)  ;Force Display to update
    	 (setvar "TileMode" 1)
    	 (prompt "\n***ModelSpace Background colour set to Black***")
    	((= (getenv "Background") "0") ;ModelSpace Background colour = Black
    	 (setenv "Background" "16777215") ;Set ModelSpace Background colour = White
    	 (setenv "XhairPickboxEtc" "0") ;Set ModelSpace Crosshair colour = Black
    	 (prompt "\n***ModelSpace Background colour set to White***")
    	(T	 ;Exit if ModelSpace Background colour /= Black or White
    	 (prompt "\n***ModelSpace Background colour not altered***")
    9,805
    Exclamation Re: Background color switching
    Another version can be found here...
    http://rkmcswain.blogspot.com/2007/0...ackground.html
    2004-07
    Detroit Michigan
    2,508
    Default Re: Background color switching
    Nice. That routine is certainly different. Does the trick!
    9,805
    Quote Originally Posted by Robert.Hall
    I typically work with black BG, but I will switch to white when taking screen captures.
    Also, it's handy to be able to toggle from black to white during a seminar or demonstration.
    Much quicker than going through the GUI.
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    (defun C:BCOLOR ()
    (cond
    	 (prompt
    Hay is there anyway to stop this lisp setting the tracking vector to black? Took me ages to figure out what had happened lol
    2007-03
    57
    Original posted here
    http://www.autocad.ru/cgi-bin/f1/board.cgi?t=8288Cp
  1. Changing Background Color
    By sinanbakir in forum Revit Structure - General
    Last Post: 2010-11-12, 04:42 PM
  2. Background color
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2010-11-04, 01:44 PM
  3. Why would MS background change color?
    By kleenhippie in forum CAD Management - General
    Last Post: 2008-01-25, 03:06 PM
  4. Background color
    By york in forum AutoCAD Customization
    Last Post: 2008-01-03, 09:27 PM
