Thread: A problematic truss...
    Member rupertv's Avatar
    2005-05
    Johannesburg, South Africa
    42
    Default A problematic truss...
    And hello again to all reviteers...
    i'm struggling with a truss/beam...see the attached file...i'm trying to get the bottom curved member to "angle" with the two top members...AND to let all the intermediate struts to join them in their angling...i can get the top two curved members to angle very easily by adding a "angle" parameter...but how do you make the others follow suit....
    HELP!!!
    PLEASE!!!
    ps...not sure if this should be here or under "families"...
    Cheers,
    Rupert
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: A problematic truss...
    Probably I don't understand what you are after but ....
    Do you want to parametrically rotate ("angle") the curved upper beams AND the curved bottom beam along the common length axis AND the joins of the sub trusses have to follow that movement ?
    2005-05
    42
    Red face Re: A problematic truss...
    i was trying to explain it in a simple way...guess i got it wrong...but in short, yes...you explained it exactly...its essentially making the entire truss "move" by giving an "angle" parameter...
  1. Truss Help!
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2010-08-25, 04:48 AM
  2. Bad Truss
    By Katika in forum Revit - Platform
    Last Post: 2008-09-16, 08:11 AM
  3. a problematic glazed roof....
    By rupertv in forum Revit Architecture - General
    Last Post: 2007-07-06, 02:33 PM
  4. Area Calculations still problematic
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2007-02-05, 06:27 PM
  5. Splines! Why so problematic?
    By jhalaby in forum Revit Architecture - General
    Last Post: 2006-08-10, 04:52 AM
