Wall is existing, opening created in Phase I. opening is a hole, but in elevation view it has no lines for edges. The lines show up when I change the phase of the opening to existing.
Workaround right now is detail lines. Any thoughts?
C
C
Sounds as though the hole is being infilled in the view you're using. Something to do with demolition phase ?
You need to check phase filters and view phases. It can get confusing.
If it still doesnt work, post it , or a simple example.
beegee.
to clarify, I know it's a hole because I see "beyond" through it. Just no edges. Tested the opening in a wall in a brand new project--wall and opening in same phase--and they work as expected. Bug?
C
