Thread: Pdf as an ole not appearing on pdf printing...
    2007-07
    2
    Default Pdf as an ole not appearing on pdf printing...
    here it is:
    I "snapshot" a part of a pdf file, paste it in Autocad (2007). The pdf appears. As I try to print in a pdf format, the inserted pdf does not print, thou, it shows on the preview.
    Anyone could help me, please...?
    2005-08
    Albania
    423
    Default Re: Pdf as an ole not appearing on pdf printing...
    Quote Originally Posted by bddcc
    here it is:
    What plot file have you choose?
    2006-10
    Chicagoland
    154
    What are you using to create the PDF? I do not use PDF snapshots, but I found I need to use the PDF Writer, not the Distiller when creating PDF's from LD2004. Distiller causes black boxes to appear where text masking used to be. I would recommend trying both to see if you get different results.
    2007-07
    2
    I actually tried to plot with my regular printer, and the inserted PDF did not print neither. I also have inserted the PDF instead of the snapshot copy/paste without any success. To print PDF, I use the PDF995 printer driver, that works perfectly for me, at least up to now !!!
    I am still looking for the solution, keep you posted if I find...
    100 Club kleenhippie's Avatar
    2002-08
    38.7867 N, 77.4917 W
    140
    Cool Re: Pdf as an ole not appearing on pdf printing...
    http://forums.augi.com/showthread.php?p=86794#post86794
    Take a look at this, I had a similar problem sometime ago.
  1. Replies: 1
    Last Post: 2017-03-06, 08:56 PM
  2. Replies: 1
    Last Post: 2013-03-25, 08:55 PM
  3. 2013: Volume in Schedules appearing and not appearing
    By Chris.Partin in forum Revit Structure - General
    Last Post: 2013-02-20, 04:19 PM
  4. 2012: Xrefs not printing or printing in light gray
    By bap020799 in forum AutoCAD Plotting
    Last Post: 2011-08-10, 07:28 PM
  5. Printing Hp Laserjet 5000- Customer Logo not printing solid
    By thomas.huckabee in forum AutoCAD Plotting
    Last Post: 2005-05-26, 08:42 PM
