Thread: Landing at top of steel stairs?
    2004-06
    Memphis TN area
    7,046
    Default Landing at top of steel stairs?
    When I make a monolithic concrete stair (ends with tread) with a landing at the top, I simply extend that top tread out to make the landing.
    On a steel stair (ends with riser), I tried to make a landing by drawing extra boundary lines at the top of the stair, similar to the boundary lines at a landing when you make the stair turn or return back, but it didn't like me doing that. It gave me an error saying "Stairs require no more than two boundaries (chains of one or more Boundary Lines)." I also tried extending the boundary lines on each side of the stair and joining those with another boundary line but it made the same error.
    Is there any way to make a top landing part of a steel stair, or do I have to create a separate floor of the same thickness as the stair treads? I wanted to make it part of the stair so that the stringers would run around the landing. I thought I had done something like this before but I can't figure out what to do. What am I missing here?
    AERC, PLLC
    Hernando, Mississippi
    2001-12
    Irvine, CA
    7,369
    1 members found this post helpful.
    Default Re: Landing at top of steel stairs?
    You need to specify one more riser than you need, uncheck "Ends with Riser" and then sketch a riser where the "stringer" would go. The railings and boundary sketch lines need to be told not to be "clever" and Auto-Detect, just assign them to Flat. I posted a blog article on this awhile back.
    2007-06
    2
    Okay, so I got that to work! Thanks!
    Now, it seems that my balusters will not connect at the base with the mono stairs. What setting did I miss?
    wendell
    2001-12
    Irvine, CA
    7,369
    Can you post a screen capture?
  1. 2015: How to extend a stair steel support under the landing?
    By Duncan Lithgow in forum Revit Architecture - General
    Last Post: 2015-02-26, 01:46 PM
  2. 2014: Stairs - mid-landing riser?
    By jessica.146534 in forum Revit Architecture - General
    Last Post: 2013-08-22, 12:33 PM
  3. 2012: Single run steel stairs with landing?
    Last Post: 2012-01-27, 03:17 PM
  4. ACA 2009- Multi landing stairs
    By Chuckyd67 in forum ACA General
    Last Post: 2011-02-22, 10:28 PM
  5. Monolithic Stairs - Landing or No? connection to floor
    By 3dway in forum Revit Architecture - General
    Last Post: 2009-10-19, 08:39 PM
