Thread: 72" Wide Plotters (only needs to output black and white)?
    I could stop if I wanted to awarren's Avatar
    2002-12
    Portland, TN
    211
    Question 72" Wide Plotters (only needs to output black and white)?
    I have a customer looking for a 72" wide plotter... He only needs black, and fairly simple lines (patterns for cloth cutting). The only thing he needs is accuracy, he prints 72" x 100' (yes feet), but it needs to maintain the accuracy +/- .005 over the 100'. Parts are small (around 2' x 2') so they only need to maintain accuracy to each other.
    I don't think the accuracy will be an issue for most new plotters. The hard part is finding something that large that is not made for outdoor signs and such.
    Any ideas?
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Default Re: 72" Wide Plotters (only needs to output black and white)?
    Quote Originally Posted by awarren
    Any ideas?
    A sign plotter was the first thing I thought of. Why wouldn't that work for your client? Most of them are pen plotters, and have some pretty incredible accuracy.The only HP I know of to handle media that big is the DesignJet 10000s. It's a banner plotter though.
    I loved the NCS so much, I joined the committee!
    "Truth suffers from too much analysis"
    I remember AutoCAD R10
    When will Autodesk port AutoCAD to Linux?
    2005-07
    2,354
    Can you get rolls of paper 100' long?
    What on earth are you plotting at 72"x100' (1828mmx30480mm) ?
    Houston
    7,519
    Exclamation Re: 72" Wide Plotters (only needs to output black and white)?
    Quote Originally Posted by Steve.Sanderson(UK)
    Our standard roll length is 650 feet. We use about 3 of those per day...
    http://www.materialconcepts.com/pages/plotter-paper.asp lists some rolls as large as 72"X1500'
  1. "Small" Wide-format scanner/plotters
    By jgrande26 in forum Hardware
    Last Post: 2011-10-05, 12:19 PM
  2. Replies: 2
    Last Post: 2007-04-18, 08:06 PM
  3. Need to output in Black and White (monochrome)
    By robert.ferguson in forum AutoCAD Plotting
    Last Post: 2007-02-27, 07:57 AM
  4. Replies: 1
    Last Post: 2006-07-28, 05:29 AM
  5. "White" filled regions print Black???
    By jabberwoki in forum Revit Architecture - General
    Last Post: 2004-06-30, 07:00 PM
