Thread: Scrolling and New Viewports
    Member KyleDasan's Avatar
    2004-08
    13
    Default Scrolling and New Viewports
    Okay,
    So I set up my drawing with annotative dimensionsing. I create a new viewport using MVIEW, and the dimensions show up. It's not until I set the viewport scale to something other than what the annotative objects are set to. Shouldn't the annotative objects be initially invisable until you set the viewport to the appropriate scale?
    The same applies when you're in a viewport, and you're using the mousewheel to zoom in and out. Again, shouldn't the annotative objects become invisible until your viewport is set to the appropriate scale?
    Attached is a drawing that you can try things out, and see what I'm getting at. Any help on this would be appreciated.
    Thanks.
    2005-09
    49
    Default Re: Scrolling and New Viewports
    I've noticed that when you use the wheel to zoom in and out it only changes the vport scale, not the anno scale. In your drawing, even though the vport was some odd scale the anno scale was still 1/8" = 1'-0" and thats why it was still visible. Same thing happens when you create a new view port, it zooms extents of the objects so the vport scale is incorrect but the anno scale is still 1/8" = 1'-0". As soon as you change either the vport scale or the anno scale in the list at the bottom right corner, then everything works properly.
  1. 2014: Scrolling with a cursor
    By boyerd492098 in forum AutoCAD General
    Last Post: 2014-05-01, 06:22 PM
  2. Scrolling in Project Browser
    By BecFra in forum Revit Structure - Wish List
    Last Post: 2008-12-05, 08:19 PM
  3. Scrolling instead of pan w/ new mouse
    By johannvonspiralspine in forum Hardware
    Last Post: 2008-07-28, 07:46 PM
  4. Scrolling ARX Error BS2004
    By Mamma Jamma in forum AMEP General
    Last Post: 2006-08-03, 03:48 PM
  5. Scrolling command line
    By davidc.54965 in forum AutoCAD Map 3D - General
    Last Post: 2006-07-14, 04:30 AM
