Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Fatal Error - can't open recovery file
  1. #11
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Fatal Error - can't open recovery file
    You can change the amount of backups for a file when you save it. Go file>save as>options and you will see that you can set it there. Usually when you do an Audit and a file save as it will go smaller. Just double check that it hasn't removed an autocad file that was linked in as I find that autocad files are a major offender.
  2. #12
    2009-01
    UK, South East England
    466
    Quote Originally Posted by Elmo View Post
    Thanks. Knew I had seen it somewhere. Audit is handy for file size reduction - good to know. I only had a location plan in there but that seems fine.
  1. 2014: A serious error has occurred-can't open the recovery file
    By sodiq.abdulsalam599422 in forum Revit Architecture - General
    Last Post: 2014-03-21, 02:18 PM
  2. Replies: 13
    Last Post: 2010-07-09, 11:58 AM
  3. Fatal error + recovery file =/= crash?
    Last Post: 2010-06-04, 03:33 PM
  4. Fatal Error when trying to Open a drawing file.
    By Khusanov90973 in forum AutoCAD General
    Last Post: 2005-07-25, 12:04 PM
  5. Fatal Error When trying to open this Acad Drawing.
    By arcadia_x27 in forum AutoCAD General
    Last Post: 2005-04-26, 07:43 PM
