What would be the best way to go about putting a 3D swimming pool into your plan?
Tim Glass
Tim Glass
If the walls and floors are straight and easily done than I would say create wall and slab styles for the pool. Otherwise you might try using mass elements.
Just my 2c.
Scott Telthorst
Quality Control Manager
Helix Electric, Inc.
www.helixelectric.com
Depends on the pool. As Scott said walls and a slab would work ok for a simple pool, but lets say you want to do a kidney pool w/ a slopping contoured bottom that any skate boarder would love to drain and skate in. I think I'd look at using the Drap tool along with either some walls for the completely vertial parts, or a mass element. You can create just about any desired contoured surface with the drape command. Or you can look on some of the 3d sites, cause I bet someone's already created one. Hope this helps.
Hey Tim, coming from a vanilla background i'd use 3D solids then convert to mass elements. Anywho i think we would all be interested in seeing the end result, if you wouldnt mind posting it
nope. And I'm not interested in it either. I mean no offense. I'm just a spoiled little brat when it comes to organic surfaces in 3D. Having been around MAX so long has spoiled me when it comes that aspect of design that I shudder when having to do 3d in cad - despite having the updated 3d engine...Originally Posted by Mr Cory
Updated 3D engine?
Thats ok, i hate meshs to begin with, no matter what enviroment they are done in, i usually stick it out with 3D solids I modelled an F1 car with 3D solids, not easy
thats gotta take a level of patience unheard of...Originally Posted by Mr Cory
Well thats what happens when your bored in 7th form CAD class and cant be bothered finishing an Accord racing car lolOriginally Posted by Steve_Bennett
