Thread: Bends
    2007-07
    Default Bends
    I am a new Inventor user with little experience. I have a problem with bends. I am trying to put two(2) 30deg bends in a piece of round rod.
    I have reviewed the information in the help area on Inventor on Bends, but it doesn't give enough information for me. Can anyone provide more help in this area?
    Williamsport, PA
    612
    Default Re: Bends
    Can you post what you have so far? My guess is a Sweep would be more appropriate anyhow if the rods are simply circular in profile.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    2007-07
    Default Re: Bends
    Thanks for the reply.
    I can't say that I have anything to post so far. I have been playing with this by drawing an elongated round rod and then trying to bend it in the middle using the bend feature. However, I have difficulty following the procedure. I am missing a step somewhere.
    2003-12
    The Hammer
    88
    Cool Re: Bends
    Were you able to get the rod bent in the middle using the bend feature? Once you have the rod created, create a new sketch longitudinally through the bar and draw a line for the bend line. Note if the line does not touch the part you will not be able to bend it. Finish the sketch and select the bend feature. Specify the bend angle, the direction as required.
  1. Are street bends possible?
    By xavier.arrazola867469 in forum AMEP General
    Last Post: 2012-01-25, 02:06 PM
  2. 2012: Customize conduit sizes and bends
    By bb1 in forum AMEP General
    Last Post: 2011-10-18, 04:17 PM
  3. OOTB Rebar Bends
    By david_peterson in forum Revit Structure - General
    Last Post: 2010-01-22, 06:39 PM
  4. Bends
    By ryoung.143621 in forum AutoCAD General
    Last Post: 2007-07-23, 05:57 PM
  5. Bends arcs
    By Hooch in forum Dynamic Blocks - Technical
    Last Post: 2007-04-23, 03:32 AM
