Results 1 to 8 of 8
Thread: NO COPY & PASTE???
    Member chad.beussink's Avatar
    2006-08
    23
    Question NO COPY & PASTE???
    All,
    I have a quesiton. I work with several different plant layouts. Sometimes I want to copy and paste from one layout to another. The problem is I have one layout that does not let me copy and paste. It acts like it copies, but it doesn't show up anywhere. I also tried doing wblocks and that didn't work. Any ideas?
    Chad
    2006-12
    1,496
    Default Re: NO COPY & PASTE???
    Using any third-party plant design add-ons?
    If you are going to fly by the seat of your pants, expect friction burns.
    Windows XP is now over 10 years old, in software terms it makes Joan Collins look like the new kid on the block. - Statler
    Everyone else being wrong is not the same thing as being right.
    2006-08
    23
    I don't think so, but many people have access to the file. There shouldn't be any xref's or anything like that.
    150700
    3,421
    Quote Originally Posted by chad.beussink
    All,
    Chad
    Is this a drawing from another person? I've had this issue before with drawings created by a customer. If I recall, the solution was to purge the drawing, using the command line version of purge, and making sure to purge all regapps.
    Active Member david-k's Avatar
    2002-11
    San Diego, CA
    78
    I believe there was an issue with the copy paste when using it with an originating drawing created on a newer version (2004+) to an older version (<2004).
    What versions are at issue here?
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Dumb question: Are both drawings in the same units? What about measurement (Imperial versus Metric)? Just a hunch.
    I loved the NCS so much, I joined the committee!
    "Truth suffers from too much analysis"
    I remember AutoCAD R10
    When will Autodesk port AutoCAD to Linux?
    2006-08
    23
    To answer some of the above questions:
    Both drawings are in english. The drawing was created in probably 2000, and we are currently using 2006 and 2007, but we have many, many drawings this same way and this is the only we have problems with.
    I will try to purge the regapps and see what that does.
    Thanks everyone.
    All AUGI, all the time Statler's Avatar
    2002-01
    At right angles to reality
    512
    Thanks everyone.
    There is a hotfix for problems with 2007 opening 2000 format drawings
    http://usa.autodesk.com/adsk/servlet...linkID=9240618
    Richard
    Some Days it's not even worth chewing through the restraints.
  1. Copy and Paste
    By rlh in forum AutoCAD General
    Last Post: 2009-06-01, 11:43 AM
  2. Copy no paste
    By cjshaw in forum AutoCAD General
    Last Post: 2009-03-31, 08:51 PM
  3. Cannot Copy & Paste
    By jeff.garr in forum AutoCAD General
    Last Post: 2006-07-23, 11:06 AM
  4. Copy and Paste
    By Robert.Hall in forum AutoCAD General
    Last Post: 2004-11-02, 04:50 PM
