Results 1 to 10 of 13
Thread: Fill Pattern Line Weights
    Default Fill Pattern Line Weights
    Why can you change the line weight of a fill pattern (when used in a filled region) but you cannot change the line weight of a fill pattern when it's associated with a material?
    I know you can change the color and pattern of a "project/surface pattern" in visibility and graphics, but there's no option to change the line weight of the pattern.
    Does anyone know how to change the line weight of a fill pattern? What is it being associated to?
    Any help would be appreciated.
    edit: i did a search and found it's not possible, this is horrible!
    2005-09
    Perth Australia
    470
    Default Re: Fill Pattern Line Weights
    The best I have been able to come up with is to make the pattern a suitable colour so those who copy my drawings in monochrome get a grey line rather than black.
    Rob
    2002-02
    St. Louis, MO
    4,695
    Fill patterns are associated with Pen 1 in your lineweight table. So I recommend reserving Pen 1 for hatching and adjusting your table as needed for best display of hatch at your varying scales. In 9.1 Pen 1 could only be set to a minumim of 0.003". In 2008 it can be set as small as 0.001". However the default in 2008 is 0.003"
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2006-10
    Arlington, Texas
    596
    Yeah, but it would sure be nice if the surface pattern and cut pattern line weights would be available in Object Styles, VG overrides, or at least the material properties. Unfortunately, one lineweight to rule them all isn't a useful "solution." Am I supposed to print sheets A2.10 and A2.11 and then change the setting to print the rest of the enlarged details so I can get some "phat" lineweights on my floor patterns?
    Come on!
    100 Club iandidesign's Avatar
    2005-03
    130
    I was just about to post a Dumb Noob Question asking how to control the line weight of model patterns. Guess it's not such a dumb question after all. A rather bizarre omission, don't you think?
    Before I head over to the wishlist, how do you Revit sages think this should be controlled?
    Geoff Briggs
    I & I Design, Seattle
    RAC 2009 on XP
    ArchiCAD 11 on Mac
    2005-11
    60
    I have encountered one exception to this frustrating lack of control - phase filters. The lineweight of model surface fill patterns will follow the projection lineweight of the phasing graphic override. I imagine the "New" phase graphic override is rarely used, but I am experimenting with using it for reflected ceiling plans to distinguish between new and existing ceiling grids.
    There are limits to this as well. Using Overridden in the phase filter instead of By Category throws out all of the by category distinctions under VG and Object Styles.
    2005-10
    Duiven, Netherlands
    18
    Why are we still thinnking in lineweights while working in a BIM? My greatest fear is that Autodesk starts developing a tool to change the lineweights in de material fill patterns. I think this will slow down the software just to get a plan looking nice.
    2005-03
    130
    As much as I like to ponder the promise of direct and seamless exchange of digital design data between AECO team members, extending as far as electronic measuring and layout tools, reality is getting a drawing "looking nice" is often exactly what I am getting paid (and told) to do. Even if it's never printed the line quality of hathing, be it surface patterns or the poché of cut elements, remains an important aid in distinguishing different materials and conditions.
    I have witnessed the difficulty of controlling the line weight of every subcomponent of a window object essentially kill the adoption of ArchiCAD as BIM tool at offices that were obsessed with drafting perfection. This is a similar situation.
    Geoff Briggs
    RAC 2009 on XP
    ArchiCAD 11 on Mac
    2003-04
    22
    I too am having difficulty getting material patterns to show up the way that I would like them to. A prime example is a brick pattern vs a horizontal metal panel. The stock brick material showing each individual brick while accurate is not very asthetically appealing. I would like to use a traditional "Heavier" horizontal line for my brick pattern. Now if I do that the brick will look just like my horizontal metal panel because I cannot change the line weight.
    This needs to be fixed.
    2004-11
    26
    Unhappy Re: Fill Pattern Line Weights
    Quote Originally Posted by aaronrumple View Post
    Not so my version of 2012 - fill patterns have been assigned as model line weight 2! Seriously, I proved this by making #1 and #2 ridiculously different, then just to be sure it wasn't controlled by something else, selecting all object styles and making them line weight 1. The hatch lines stick out like a sore thumb. What is controlling this?? Why hasn't this been fixed? See post by bregnier dated 3/11/2010 that says the same thing, but with no answer. Looks like a bug to me.
  1. Cut Pattern Line Weights
    By Buffalo Pot Pie in forum Revit Structure - General
    Last Post: 2010-02-08, 01:46 AM
  2. Footing line weights and hatch pattern
    By mikemck in forum Revit Architecture - General
    Last Post: 2005-12-09, 04:28 PM
  3. Line Weights of Fill Patterns
    By rgranja508683 in forum Revit Architecture - General
    Last Post: 2005-01-14, 01:04 AM
  4. Fill Pattern Line Weights
    By Batman in forum Revit Architecture - General
    Last Post: 2004-12-23, 02:52 AM
  5. surface pattern line weights?
    By woethesinner in forum Revit Architecture - General
    Last Post: 2004-11-08, 03:10 PM
