Thread: Rotated foundation pile
    2006-01
    45
    Default Rotated foundation pile
    Hello all,
    I created a foundation pile and as long as this pile is vertical it works fine.
    However, when I create non-vertical piles (by turning off Always vertical and tunring on Workplane based). I can create my piles.
    BUT
    The symbolic lines that I used to show the center of the pile is not shown anymore. I can see it is there when I create a section parallel to this workplane. I think I need something like Family Pre-cut in plan which can be set for a structural column.
    Also, I would like to read the slope property of the pile to put it in a schedule - I think I have to create a Shared parameter for this. Re-thinking this, perhaps I should redesign my family and add an angle parameter (slope)....
    Do you have any other good ideas?
    Renzo
    2005-10
    321
    Default Re: Rotated foundation pile
    Renzo,
    Without looking at the family I can only make a few suggestions. First would be to use a model line instead of a symbolic line. You can set the visibility so that it behaves like a symbolic line. This should help with the plan representation. I would suggest creating a ref line and using the solid sweep tool. It may even be benificial to use a profile family to control pile diamater/shape if it tends to vary a bit. You can then constrain the ref. line with your angular dimensions, you may have already done this.
    Shared parameters should do the trick to the info on a schedule.
    -Jeff
    2006-01
    45
    Hello Jeff,
    That make sense... Thanks for your quick reply
    Renzo
  1. 2013: Offset Foundation from Foundation Wall
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2013-09-19, 04:19 PM
  2. 2012: Foundation tag aligning with foundation edge
    By thanus857097 in forum Revit Structure - General
    Last Post: 2012-01-10, 08:08 PM
  3. Selection Window Rotated When USC is Rotated
    Last Post: 2009-01-05, 01:47 PM
  4. Rotated Titles for Rotated Views?
    By Kiteman48 in forum Revit Architecture - General
    Last Post: 2008-07-10, 05:55 PM
  5. Angled pile cap
    By tmad101185 in forum Revit Structure - General
    Last Post: 2008-02-19, 07:09 PM
