Thread: Add new objects with OD to an SHP connected
    2007-05
    São Paulo - SP
    25
    Default Add new objects with OD to an SHP connected
    Hi,
    I need to Add several DWG objects with Object Data attached to Shape connection.
    How can do It without to loose the attribute data?
    Tks,
    TN/KY Area
    1,640
    Default Re: Add new objects with OD to an SHP connected
    You can export those map objects with OD to another shp file, then connect to it and use the bulk copy to append it to the other shp file. I haven't tried it yet but that the way it is supposed to work.
    I could stop if I wanted to ekubaskie's Avatar
    2001-12
    Anchorage, Alaska
    324
    Before executing a command that will zap an object that you'd really like to keep, select them and do "Copy with base point" with a known base. Do your command, then paste using the previous point to get your objects back.
    I do this often enough that I made a couple toolbar buttons. One does copybase at 0,0 and the other does a paste at 0,0. It also gets around the part where "Paste to original coordinates" does not act within the same drawing.
  1. Deleting connected MEP objects
    By elaurier in forum AMEP General
    Last Post: 2011-07-13, 12:49 PM
  2. Disconnect connected objects
    By seve700 in forum 3ds Max - General
    Last Post: 2010-06-12, 11:06 PM
  3. Pipe 'Not well Connected'
    By dfgy30 in forum Revit MEP - General
    Last Post: 2010-04-12, 10:03 PM
  4. Well connected piping
    By awascher in forum Revit MEP - General
    Last Post: 2008-02-28, 01:09 PM
  5. Fields in ttl blk connected to SSM
    By cadman_meg in forum AutoCAD Fields
    Last Post: 2008-02-14, 04:33 PM
