Thread: Aluminum Storefront Family
    2003-10
    Hawaii
    31
    Default Aluminum Storefront Family
    I would like to add a simple storefront entrance to a project but could not find a ready made family in the Web Library, Rugi, etc. I might have missed it? Tried modifying a fixed window but can't get it to sit in the wall right. It projects out from the face of the wall (still learning about creating families). All I need is a 1 3/4" x 4" frame section type storefront. Anyone know where I can find one that's already been created?
    2003-05
    5,153
    Default Re: Aluminum Storefront Family
    There is a standard curtain wall storefront that is in the shipped Metric template. I assume there would be one in the Imperial template also.
    Have you looked at that?
    2003-04
    Chino, CA
    4,756
    Have you tried using the Curtainwall tool to create your storefront? Typically, a storefront is not a pre-loaded family, but rather created to your own configuration using the Curtainwall tool. Create a wall, change its properties to Curtainwall in the Properties pull-down, then use the Curtain Grid and Mullions tool under the Modeling tab to create the grid and add mullions.
    2004-05
    25
    I am sure that there are better ways to do storefront, but I just model them in place. I find that no two storefronts I do are the same. If you do have a bunch that are the same you can just copy them from location to location. The only bad part of that is I don't like to model the openings with the window because it does make them difficult to copy and rotate. I create the openings by editing the elevation of the wall. I just feel like I have more control over the windows that way.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    I know I've posted numerous aluminium storefront windows and doors on Rugi a while ago. some have transoms, some sill mullions some single sidelites, some double. So you should be able to take one of those and modify as needed.
    I typically make them as door and window families if I need multiple instances. Curtain walls are great in design but I usually need to schedule them as windows or doors.
    Scott D. Brown, AIA
    BECK
  1. Aluminum Storefront Window Detail Components
    By Dimitri Harvalias in forum Revit Architecture - Families
    Last Post: 2012-02-19, 10:32 PM
  2. Arched Storefront Family
    By joek.136617 in forum Revit Architecture - Families
    Last Post: 2007-03-30, 06:15 PM
  3. Architectural - Aluminum Storefront Section
    By .chad in forum Dynamic Blocks - Sharing
    Last Post: 2007-03-15, 03:53 PM
  4. Nest a storefront in a window family?
    By ron.sanpedro in forum Revit Architecture - Families
    Last Post: 2006-03-16, 10:02 PM
  5. Editing standard storefront family
    By craighowie in forum Revit Architecture - General
    Last Post: 2005-12-08, 12:27 PM
