is there a way to make a metal horizontal corrugated wall or is there one already made with in revit
thank you
jj
thank you
jj
If you have a profile of the corrugated wall you plan to use you could extrude to form the wall, otherwise you might find something at this website. It has a host of steel roofing profiles in revit and other formats...
HTH
I make one in Revit. We use the following construction a lot in the office.
Inside= 10mm plasterboard/90mm timber/steel stud/16mm corrugated cladding. I use 75mm surface pattern to indicate the cladding pattern. I have images for all the different corrugation colours for rendering. We do not model the profile, but will show the profile with repeating details when needed.
Image attached showing material when rendered.
Tobie van Loggerenberg
Architect RAIA
Great little image there Tobie, rammed earth walls (I'm assuming) look great as wellOriginally Posted by tobie
thanks to all
this steel profile site is cool
