Results 1 to 7 of 7
Thread: 2D From 3D
    Member Masroor Javid's Avatar
    2004-12
    Athens Greece
    36
    Question 2D From 3D
    I wish I could easily produce -from my 3D ADT or ACA Files- ACCURATE and WELL ORGANIZED 2D drawings for my colleagues or collaborates who do not use 3D in their work.
    Having the architectural drawings in 3D is fine, but how can I send updated DWGs to the Civil and or Mechanical Engineer teams who are to work on the same project?
    By Accurate and Well Organised DWG I mean that the 2D product needs to be a normal DWG file organised in layers, having blocks and generally editable for anyone who will need to work further on it and to produce a new file with Civil work or Electro-mechanical data on it.
    2002-09
    Madison, WI
    4,440
    Default Re: 2D From 3D
    Have you tried using the export to autocad feature? It usually works well.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Have you tried all 3 options when working with your consultants?
    • eTransmit
    • AECOBJEXPLODE (different than eTransmit)
    • Having them use object enablers to view the ADT objects
    Just wanted to see if these were all options you've tried.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2004-12
    Athens Greece
    36
    Dear David, thanks for your reply.
    Export to... works well, but does not actually produce a 2D drawnig. A Mechanical engineer collaborate is most likely to work on a simple 2D DWG in order to produce his part of the project.
    What I really need to to produce a series of simple 2D DWGs -that is plans, elevations and sections- which i can send to Civil and Mechanical (or other) engineer teams so that they can work on the same project in 2D as they do normaly.
    2004-12
    Athens Greece
    36
    Thanks Steve,
    I did not know AECOBJEXPLODE. It seems to work well generally. Leaves out the roof and sets of sinks etc. in the bathrooms.
    Thanks again.
    2002-09
    Madison, WI
    4,440
    Ok, how about the "Flatten" command? I haven't used it, but I think that's another option for you.
    Dave Peterson
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,845
    Quote Originally Posted by m.javid
    Thanks Steve,
    Thanks again.
    Export to AutoCAD does an AecObjExplode. If you are in a view that displays objects as 2D (eg, top/plan view for walls), you will get 2D results.
    David Koch
