Thread: Copying floor plans
    100 Club WolffG's Avatar
    2003-06
    Syracuse NY, USA
    157
    Question Copying floor plans
    This may be somewhere in the documentation, but I can't find it.
    Is there a way to copy floor plans from one floor to other floors without retracing everything?
    Using copy and paste seems to copy everything back to the same floor.
    I'm not interested what the architect has to say about his building.
    I'm interested what the building has to say about its architect.
    2007-02
    Boston, MA
    92
    1 members found this post helpful.
    Default Re: Copying floor plans
    After copying did you try Edit>Paste Aligned>Select Levels By Name...
    Pick from the list and you can paste to multiple levels at once.
    CD
    100 Club MNsnowtaTy's Avatar
    2007-06
    Minnesota
    142
    You have to copy to the clipboard and then pick paste aligned and then select levels by name from the paste aligned menu. Then pick all the levels that you want to paste the floor plan on and you should be in business.
    2003-06
    Syracuse NY, USA
    157
    Smile Re: Copying floor plans
    Thanks very much. This has to be a record reply time. Two responses in under 10 minutes!
  1. Copy dependent floor-plans to ceiling-plans.
    By thomas.163390 in forum Revit Architecture - General
    Last Post: 2010-07-19, 01:59 PM
  2. Detail lines Floor Plans and Ceiling Plans
    By techsupport.161645 in forum Revit Architecture - General
    Last Post: 2010-02-05, 06:57 PM
  3. Schematic Design, Area Plans, and Floor Plans
    By bleonard in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-02-14, 06:51 PM
  4. Level tied to Ceiling plans instead of Floor Plans
    By Andre Baros in forum Revit Architecture - General
    Last Post: 2006-01-27, 01:06 AM
  5. Allow underlays of Reflected Ceiling plans in Floor plans
    By juggergnat in forum Revit Architecture - Wish List
    Last Post: 2004-08-29, 06:49 PM
