Results 1 to 6 of 6
Thread: Sheet Set List - Row Removal
    Member ssmith.62044's Avatar
    2003-12
    11
    Question Sheet Set List - Row Removal
    Has anyone discovered a way to delete rows from the Sheet Set List? Not just content, but the actual row (as you could in ADT 2006).
    The Silent Type Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,691
    Default Re: Sheet Set List - Row Removal
    If you are referring to the autocad table that can be generated from the list of sheets in the sheets tab of Project Navigator, then you should be able to select an individual cell, right click on it and choose to delete the row. I haven't tried it, but that is the basic way to go about it in previous versions. Please keep in mind that the list will be overridden if it is updated.
    Steve Bennett |CAD Manager
    Moffatt & Nichol | Adventures in BIM
    2003-12
    11
    no longer an option in 2008. Will not allow you to delete linked cells. very frustrating.
    2007-05
    25
    I have played around with this quite a bit and I have also been updating my network and I discovered that you can delete rows etc if they are not linked to the shetset list.
    I discovered this because the link broke between the sheet set manager in the project browser as I ahve shifted all my files around but once I hit up date i could not work out how to break the link again to be able to delete the rows.
    Yes this is ver frustrating
    Member DWS44's Avatar
    22
    Has anyone figured out a way around this yet? I'm stuck with the same problem...need to edit a sheet list in 2008, but can't figure out how to break the link to be able to delete rows.
    Dave Smith
    Technician Manager
    Delta Airport Consultants, Inc.
    Charlotte, NC
    2015-12
    4,691
    umm... explode?
  1. Link Sheet set to Sheet List Table and Excel
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2013-05-19, 05:52 AM
  2. Sheet Set Manager sheet list (Data link)
    By Blakester122 in forum AutoCAD General
    Last Post: 2010-02-17, 03:02 PM
  3. Xref Plot Scale List removal
    By rklee in forum AutoCAD General
    Last Post: 2008-04-04, 01:44 PM
  4. Insert Outside Sheet Set into Master Sheet Set List
    Last Post: 2007-11-28, 12:19 PM
  5. Replies: 3
    Last Post: 2006-04-26, 02:35 PM
