Thread: Deleting ctb files
    2002-10
    4
    Default Deleting ctb files
    Good morning. I was curious if there is any reason why I should not delete all of the ctb files created when you install AutoCad (ie. monochrome, 25% screening.....)? Our company has a lot of ctb files created by employees and we would like to delete everything except for our standard file. We do nothing with our plotter except black and white prints. We never do and renderings or colored drawings on the plotter. I would just like to make sure that nothing catastrophic will happen if I delete a ctb file that needs to remain. We are using Desktop 2004 and our plotter is a HP Designjet 500. Thank you in advance for the help.
    Earth
    9,805
    Default Re: Deleting ctb files
    We map everyone to our network location for CTB files, so the OOTB "stock" ones (on the local drive) are just ignored. It wouldn't hurt to delete them though.
    R.K. McSwain | CAD Panacea |
    2002-10
    4
    Thanks, I appreciate the reply. We actually tried to map it to the ctb file on the network but people keep switching them for some unknown reason. Now we had someone make plot files and send them out to the printer and all the lines came back wrong. I am just going to move all the unused files to another folder. Thanks again for the help.
  1. Deleting imported DWG files
    By david.delcher in forum Revit Architecture - General
    Last Post: 2017-05-16, 04:32 AM
  2. .ned and .nwf - deleting files
    By ev.dysart280615 in forum NavisWorks - General
    Last Post: 2011-09-13, 05:22 PM
  3. Deleting Temp Files
    By rjcrowther in forum Revit - In Practice
    Last Post: 2007-05-29, 11:01 PM
  4. Problem Deleting Files with VBA
    By CADdancer in forum VBA/COM Interop
    Last Post: 2006-03-16, 08:09 PM
  5. Deleting sheet set files?
    By chrise.68617 in forum AutoCAD Sheet Set Manager
    Last Post: 2004-11-05, 12:05 AM
