Results 1 to 8 of 8
Thread: Cannot Open certain drawings
    2004-08
    3
    Exclamation Cannot Open certain drawings
    i'm using autocad 2004 and i can't seem to open some drawings. and it throws the following error "Fatal Error: Unhandled access violation reading 0x0008 exception at 33ed2d70h". anybody know how i can go about fixing this or opening the files?
    any help would be appreciated.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Cannot Open certain drawings
    Try inserting the problem drawing as a block into a new empty drawing.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-10
    Arizona
    2,337
    Try posting one of those problem drawings here
    or send one to me so that I can poke at it here
    and see what makes it twitch.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-03
    13,499
    Hi
    As you're running and Autodesk 2004 (or 2005) product have you tried the following -
    <snip>
    Error Reporting utility let's you send in reports to Autodesk if AutoCAD crashes. Do it and make the next Service Pack or Release more stable. If AutoCAD ends unexpectedly, and the Error Report message is not displayed, make sure the REPORTERROR system variable is set to 1.
    </snip>
    What Operating System are you running + does this have the latest Service Packs and Critical Updates installed?
    Check out the following thread (the bit of interest is the snippet from Ed Jobe) -
    Red AutoSNAP marker
    Issues/Problems with random crashes are notoriously difficult to resolve due to their very nature.... hopefully Ed's little guide will help.
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS19369 - Recover damaged drawing when RECOVER command is not successful
    Have a good one, Mike
    2004-08
    3
    Quote Originally Posted by gpope
    tried that and it still crashes.
    Quote Originally Posted by mjfarrell
    email me and i'll send you the drawing from there.
    Quote Originally Posted by Mike.Perry
    i'll try that guide thanks
    thanks everyone for the help. i'm still poking away at this
    I could stop if I wanted to michael.12445's Avatar
    2001-03
    350
    I don't have experience with 2004, but we sometimes have a similar problem with 2002. If AutoCAD gets through part of the process of opening the drawing before it crashes, we've found that you can sometimes get to a Command: prompt by pressing the ESC key after you click the "Open" button on the file dialog but before AutoCAD crashes. (ESC, which AutoCAD interprets as "Cancel," stops AutoCAD from regenerating the drawing). If you can get to a Command: prompt, then you can run AUDIT to try to fix the data on which AutoCAD is choking.
    We have also found that Intellicad (www.cadopia.com - I think they have a free trial download) can sometimes open drawings that AutoCAD cannot. Sometimes just opening a drawing in Intellicad and saving it with that program makes the drawing usable in AutoCAD again.
    Michael Evans
    2004-08
    3
    ^^ thats a really good idea. it seems to be crashing right after it goes to regenerate. i finally was able to open the drawing with autocad 2005 but i'm going to try that suggestion just to see if it works.
    thanks everyone
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, South Carolina
    149
    I use restore in 02, then when I have the drawing open I'll -wblock it to the same name (if it's only in one space) using a crossing to get only what I want (usually everything in the normal extents), then close the file WITHOUT saving. I know most of you folks out there use model and paper space, the company I work for goes model only, so this is a solution that works about 98% of the time for me, plus it has the added benefit of purging the drawing to the max. If you have unused layers (or dimstyles or textstyles) you want to keep in the drawing, just put something on the layer (or dimstyle or textstyle) and include it in the -wblock. You can delete that stuff later and you'll still have the layers (or dimstyles or textstyles)...
    Celie
  1. Replies: 2
    Last Post: 2011-04-28, 02:04 AM
  2. Open Drawings
    By JeffClark in forum AutoCAD General
    Last Post: 2010-08-10, 03:56 PM
  3. How to open drawings from a webpage
    By jgratton in forum CAD Management - General
    Last Post: 2008-03-10, 04:10 PM
  4. Where do you open your drawings from?
    By StephenJ in forum CAD Management - General
    Last Post: 2006-09-22, 09:55 PM
  5. Can't open drawings
    By tammy346 in forum AutoCAD General
    Last Post: 2004-09-30, 11:11 PM
