Thread: switch Annatative On/Off
    I could stop if I wanted to CadDog's Avatar
    2005-06
    So Ca
    411
    Default switch Annatative On/Off
    <<<AutoCad 2008>>>
    I would like to know if there is away to switch ANnotative on a current dimstyle
    Without needed to open the dialog box and selecting the dimstyle to Modify and than tabbing over to fit/annotative...???
    I'm trying to reduce these steps by maybe creating a quick key input which switches on and off
    Annotative...
    Thanks
    Here is the only help I have found so far which clearing notes the new variables:
    http://www.hyperpics.com/system_variables/
    Jesse
    aka CadDog © 1994
    All is Well until It Fails
    Remember, that what you teach me here you are also teaching others...
    2005-06
    So Ca
    411
    Default Re: switch Annatative On/Off
    OK, if anyone cares, here how I finally done it...
    (defun c:annoff ( / )
      (vl-cmdf "_.DIMSTYLE" "AN" "N" "DIM20" "y" "" "")
         (vl-cmdf "")
    This is only one small part of what I'm doing but it works...
    This simply toggle off the Annatative on dim style select or noted above...
    Hey, for me it a big start...
    Jesse
    aka CadDog © 1994
  1. Switch to LT?
    By jmd1959 in forum AutoCAD LT - General
    Last Post: 2010-10-07, 09:09 PM
  2. Switch to .NET?
    By mcoffman in forum VBA/COM Interop
    Last Post: 2006-12-04, 07:43 PM
  3. 4g RAM and the /3G Switch
    By david.kingham in forum Revit - Hardware & Operating Systems
    Last Post: 2006-11-06, 08:12 PM
  4. Win XP Pro and /3GB switch
    By jguest in forum Windows XP
    Last Post: 2006-03-20, 09:05 AM
  5. Double switch plates and switch/outlet combos
    By christo4robin in forum Revit Architecture - Families
    Last Post: 2004-12-04, 03:23 AM
