Dilbert
I actually have no problem with a mapped drive, but back to the initial question: if you have it pointed the same way the drive is mapped (via shared name/directory structure) why couldn't you simply do it the way you wish? In other words, why can't you just set up all your scripts to search your network path? It should work even if a drive letter is assigned, if it's a shared network path it won't care about the drive letter, it'll look for the computer then the shared location on that machine.
