I have found a few “bugs” or a bit of strange behavior in the Snaps tool. First off, when you turn off snaps they don’t stay turned off once you close Revit. For example, I don’t like to have the “nearest” snap on all the time. I fact, I never want it on. I am able to turn it off – great, but the next time I restart Revit the “nearest” snap is back on again.
Secondly I like to use the function keys for my snaps. Some of the snaps work as function keys and some don’t. “Snaps off” for example does not work at all when assigned to a function key. Also when function keys are assigned as snaps they don’t show up in the snaps dialog box. If I assign SP to snap perpendicular I get a helpful reminder in the snap dialog box that SP is the short-cut. If I assign the F4 key to snap perpendicular the helpful reminder comes up blank.
Lastly, does the F1 key have to be hard-coded to the help tool? I need all my keys for commands. The F1 key is prime real-estate – give us the ability to change it. This goes for the F8 key also.
Thanks
Scott Hopkins
