Thread: Exterior Wall Material
    Member footbridge's Avatar
    2007-02
    Boston Area
    37
    Question Exterior Wall Material
    I've added an addition and now one of the exterior walls is partially interior, new roof bisects this wall. What is the best way to keep the exterior portion the same and change only the interior without change the exterior?
    2007-08
    2
    Default Re: Exterior Wall Material
    I would recommend looking at stacked walls. You can make the bottom portion of the wall using your interior wall, and the top with exterior, and if you should change either of those two, the stacked wall will reflect the change.
  1. Exterior Material Composition
    By Captainkb in forum Revit - Gallery
    Last Post: 2010-10-04, 07:48 PM
  2. Creating a multi-material exterior wall
    By mmeaney in forum ACA General
    Last Post: 2008-11-06, 06:43 PM
  3. exterior wall material breaks off
    By boyd.112779 in forum Revit Architecture - General
    Last Post: 2007-04-20, 11:21 AM
  4. Material changes in exterior wall
    By Michelle Gibson in forum Revit Architecture - General
    Last Post: 2005-04-19, 08:37 PM
  5. Exterior Material Annotation & Schedule
    By barathd in forum Revit Architecture - General
    Last Post: 2004-08-16, 04:00 AM
