Just find :ArchiveLocal and replace everything between that and :CopyCentral
I would recommend getting a text editor that will really help you see what is going on, I would recommend Notepad++ http://notepad-plus.sourceforge.net/
thanks. i figured it out. So what does the RAC 2008.bat do exactly?
It looked something like this
Code:@echo off regedit.exe /s "\\nevada\drawings\Revit\Files\Batch Files\2008\RAC2008.reg" set KBS="\\nevada\drawings\Revit\Files\2008\RAC2008\Keyboardshortcuts.txt" set INI="\\nevada\drawings\Revit\Files\2008\RAC2008\revit.ini" set RVT="c:\program files\Revit Architecture 2008\Program" set TUT="\\nevada\drawings\Revit\Files\Defaults\Architecture\2008\TutorialsBuildingImpENU.chm" set EXT="\\nevada\drawings\Revit\Files\Extensions" set EXTLOC="c:\program files\Revit Architecture 2008\Program\Extensions" xcopy /c /v /q /y /i /r /h %TUT% %RVT% xcopy /c /v /q /y /i /r /h %KBS% %RVT% xcopy /c /v /q /y /i /r /h %INI% %RVT% mkdir %EXTLOC% xcopy /c /v /q /y /i /r /h /s %EXT% %EXTLOC% del "C:\Program Files\Revit Architecture 2008\Program\Content.rcl" set path="c:\program files\Revit Architecture 2008\program" start /high /max Revit.exe
Fixes some registry keys for the no start problem, if you don't have a problem with revit not starting then don't worry about it.
Copies revit.ini and keyboardshortcuts so every computer is the same
Copies the tutorials because my network deployments seem to miss it for some reason
Copies some files for extensions
And deletes the content.rcl which tells revit to download the rest of the content, usually not a problem but has been once or twice
Most people wouldn't go to this length, but what can I say, I'm an anal *******
Just delete this from the original script
Code::SetupStart call "Q:\Revit\Files\Batch Files\2008\RAC2008.bat" cls @echo off echo Done! echo Local File created in C:\Revit Local Files\%PRJ% type "Q:\Revit\Files\Batch Files\echo.txt" pause
aha. i did just notice though you are specifying the path for the keyboard shortcut file. so i could do the same really. i could say:
(in the RAC2008.bat file)
set KBS="\\Program Files\Revit Architecture 2008\Program\Keyboardshortcuts.txt"
right? that way it pulls the correct txt file from their own cpu that they have edited already.
If you don't want to change their keyboardshortcuts then just don't replace it with anything...I believe you're overthinking this...
Has anybody updated their code to auto open the workshare monitor? Its just another safety net that we would like to standardize.
Nick
