Thread: Other Software to support Auto-CAD
    2005-01
    84
    Arrow Other Software to support Auto-CAD
    I am using Auto-CAD-2007 and trying to create a Master Plan of the Facility consisting of dozens of x-ref files on both 2D and 3D. I know there are several numbers of software out there by Autodesk that support both horizontal and vertical applications like Auto-CAD Architectures, etc, What other software do you think I need to support my only software mentioned to successfully create my project the easy way. And what kind of Machine hardware’s requirements do you think are needed to run suggested software to run smoothly.
    Ted (Auto-CAD-2007)
    2005-08
    Albania
    423
    Default Re: Other Software to support Auto-CAD
    Quote Originally Posted by Holceste25
    Ted (Auto-CAD-2007)
    Therefore your project is on field architectures think you should use AutoCAD Architecture 2008.
    Maybe this can't help in fact I am not degree for architecture but I am degree for mechanical engineering.
    Just a think.
    Certified BIM Addict Brian Myers's Avatar
    2003-02
    Working in Cyberspace
    1,682
    Revit would be an option as well, but you can do what you need to do with AutoCAD Architecture... it was designed for projects like the one you are doing.
    Brian Myers
    Sr Applications Engineer, Seiler Instrument | Autodesk Certified Instructor (ACI) Revit Architecture
    Creator of the Revit Users LinkedIn Community | Author of Revit Videos @ Lynda.com
  1. AUTO LISP
    By jamal491 in forum AutoLISP
    Last Post: 2010-07-07, 12:00 PM
  2. Auto CAD 2009 Software keeps crashing
    By eeker in forum AutoCAD Action Recorder
    Last Post: 2009-05-09, 11:56 AM
  3. Auto Cap
    By cadman_meg in forum AutoCAD General
    Last Post: 2008-12-03, 11:14 AM
  4. Acad.pgp / Auto.lsp
    By Sponge Bob in forum AutoLISP
    Last Post: 2008-11-15, 07:15 AM
