Thread: How to rotate view from SW Isometric view
    2006-08
    31
    Default How to rotate view from SW Isometric view
    I have pipes drawn in 3d and they'll be exported to a .png for graphics. Customer likes the SW isometric view, but wants me to rotate the view 32 deg around the z axis from where they are now (in SW view). How do I do that?
    TIA!
    Cargo
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: How to rotate view from SW Isometric view
    Quote Originally Posted by cargo33us
    TIA!
    Cargo
    Use VPOINT command
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    2006-08
    31
    Quote Originally Posted by zoomharis
    Use VPOINT command
    Thanks, that helps.....sort of.
    If my xy plane shows 35.3 and my "from" is 225 - what do I need to do to rotate it 32 deg about the z axis from where it is now?
    0,0,0 The Origin
    8,569
    Enter either 193 or 257 in the "from x axis" box and click OK.
    Bear in mind that there are 2 radio buttons at the top of the box - "absolute to WCS" and "relative to UCS". The choice may may a difference depending on the true orientation of the parts and your current co-ordinate system.
    John B
  1. Replies: 5
    Last Post: 2011-12-28, 05:30 PM
  2. Scaling in isometric View
    By Binu Mathew in forum AutoCAD General
    Last Post: 2008-08-29, 11:53 AM
  3. Isometric view
    By dzatto in forum ACA General
    Last Post: 2008-07-07, 05:28 PM
  4. 3D to three view w/isometric?
    By rennichd in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-10-09, 11:13 PM
  5. Drawing in isometric view
    By cadkiller in forum ACA Wish List
    Last Post: 2004-11-07, 04:55 PM
